Hi, i'm new to class-D amps AND to this forum 🙂
After reading some about it on this forum I tried to do build a simple amp using the tl494 (mostly used for switching psu's) and fet driver IR2110. I didn't know that Vss should be between -5 and +5v, so i'm going to order a new 2110.. and I wrote a whole new schamtic 'cause i didn't like using the 494 anyway 🙂
The schematic I wrote is at: http://www.plasser.nl/amp.jpg
(it was too big to attach)
I wondering if it would be worth building it... can anyone tell me if i should change anything?
Thanks in advange!
Grts, Tom
Thanks in advange!
Grts, Tom
Hi Tom
Tom You have gathered much Information from Crest LT schematic as well as from Sergio's Class-D Amplifier Prototype.
You can simpliFy it even further , You can use :
Single Supply operation,
H-bridge in BD mode.
ampman
ampman
Re: Hi Tom
Yeah, I did look at the Crest LT schematic, although I was already planning to use the LM119/219/319 and IR2110. I kinda stole the level shifter to bias the logic from the other stuff 🙂
Yes, I could make a H-bridge, but that would require 2 gate drivers, and after all it's just an experiment 🙂
Greetings, Tom
amp_man_1 said:Tom You have gathered much Information from Crest LT schematic as well as from Sergio's Class-D Amplifier Prototype.
Greetings, Tom
