Tpa3255 or Irs2092 - My first amplifier
Hi all,
It's one of my first posts here but I spend a lot of time to read your valuable forum. I am a beginner in electronic so please don't be too much rude with me... ;-)
I want build my first amplifier during this period of quarantine, to try to learn something and spend my time a little bit better.
I have a lot of concern about it, but the first, is which type of board I have to pick. The 2 main options are tpa3255 or Irs2092.
The tpa3255 seems that the best one is the one provided by 3e audio.
For Irs2092 I have some options. The first 2, is an already build and tested boards:
Sure Electronics 2x125w
WONDOM | STORE
LJM L15D-power (It is good because have integrated already speaker protection and rectifier.
LJM de Audio ensamblados L15D POWER IRS2092 300W Mono placa amplificadora de potencia con proteccion de energia HiFi Digital AMPLIFICADOR DE POTENCIA DE Audio|power amplifier board|amplifier boardmono power amplifier board - AliExpress
The second option (and it is my preferred) is buy a DIY kit, to build manually my amp with the solder.
LJM L15D-PRO is the only available kit that I found, and I don't know if it is LJM original one, with a good set components (And the rectify part is missing, only the speaker protection circuit is available)
Nuevo Dual canal L15D PRO Clase D IRS2092 IRFB4019 AMPLIFICADOR DE POTENCIA ESTEREO DIY Kit (, 2) 300W|amplifier diy|amplifier classpower amplifier - AliExpress
In theory my target is build an integrated amplifier with a preamp and a DAC included.
My objective is that the quality of sound must be best of possible (HIFI?) and have a really quite output in idle without hiss, pop, or ommm noises. (I own a DENON 3500, and could be nice if my selfmade amp could be better that this)
The preamplifier that I have in mind to build and use with the above boards is this one:
Mezmerize B1 Buffer – diyAudio Store
What do you think about it?
Could you help me? (@ljm_ljm)
Thank you a lot.
Hi all,
WONDOM | STORE
Thank you a lot.
I have the LJM L25D, running on a +/-55V SMPS for about 4 years. Works very well, quiet and can use a 50k or 100k pot, no need for a pre-amp for me.
Alternately - also use a TA2020 4-channel amp quite a bit, for Sure - AA-AB009 model #. It is only 30-40w but useses an old laptop brick of 19-24V and has all protection built in.
I would buy a pre-built class D amp - or go fo a Class AB if you want to learn to solder. Class AB is much easier for a first build and soldering.
Thank you for your suggestion, but I need a preamp, because I need to have several input (for a DAC or a streaming board).
I want as well use this amp in conjunction with my AVR.
In Terms of audio quality si better tpa3255 or irs2092?
