Motivation.
My first three-way started with my wife and one of her friends. No, really.
The friend inherited a really nice turntable from another friend's family. Micro Seiki with a nice cartridge, but the turntable speed wasn't constant. So I volunteered to try my hand at fixing it. A little disassembly, cleaning some pots, some calibration, and it was good to go.
But there was a problem. When I tested it with my stereo system, swapping out my old late 70's Technics... it was awesome. I heard things I had never heard before. Dammit, now I need a new turntable & cartridge. 🙄😆
I did that. Just purchased a Fluance with a decent Ortofon cartridge. It sounds great. BUT... the mids are a little harsh, and I can hear some nasty distortion which wasn't evident before - because the rest of the sound is so clean.
And so the next domino to fall is the speakers. Currently I've got a set of Cambridge Soundworks M80's. They're a 3 way design, but looking at the impedance plot I'm not sure it even has a crossover inside. (And the distortion - meh.)
I built a couple of sets of speakers back about 20 years ago, but have never tackled a 3-way design. But now we have decent simulation software, I've got some decent measurement hardware, the kids are gone, and I'm retired so every week is six Saturdays and a Sunday. 🙂 I've spent some time lurking here, and I think I'm ready to go. And so here's the start of my build thread!
Objectives.
I was originally thinking of John Krutke's designs with his ZA14W woofer/midrange, but that appears to be NLA, at least for now. And I'm not sure how much bass I could squeeze out of that design. So, onwards, more reading.
I like Jim Holtz and Curt Campbell's designs, if for no other reason than that they're well documented. Unfortunately, so many of those designs are also NLA. I finally zeroed on on the Anthology design. It's an MTMWW design which utilizes the Dayton Audio RS225 woofer, the SB Acoustics SB15NRXC30-8 5" midrange, and the Seas 22TFF 3/4" tweeter. Some sims show that I have some hope of using this as a starting point for varied other designs, including a 2-way, a W(T/M)W center channel, or even a simpler TMW.
And so I've got my MiniDSP UMIK measuring microphone, my impedance jig, an oscilloscope (if I need it), taught myself a little bit of VituixCAD, and off we go!
Why mess with a winning combo (the Anthology design)?
Why change what works? The Anthology seems to be well regarded. But, per my points above, this project is not only about building a speaker, but about learning how to build a speaker. Jim & Curt have given enough design details on the crossover and enclosure that I think I can do some tweaking and some learning. And if I fail, I can always go back to their design!
The drivers.
The first thing I did was sim the Anthology design with the stock crossover. OK, works, except that the published design appears to have the tweeter wired out of phase; inverting the phase makes it look great. But... I've read that Jim really likes the SB15CAC woofer for midrange. I subbed the SB15CAC in for the SB15NRX2 (since the NRX is on its way out), and sims beautifully. Better than the NRX2, which has a nasty mode at around 10k that pushes its way into the overall response.
Next step - what about the tweeter? The SB Acoustics SB21RDC (or for that matter, the SB19 and/or SB26) appear to be close to drop-in into the Anthology design, with just a little tweaking, and they seem to be well regarded. An additional advantage is that there's a design for a 3D printed waveguide for these drivers, giving me even more to play around with/learn about!
For the woofer, I see no reason to vary from the Dayton Audio RS225-8.
The advantage of the mid and woofer is that there are other sizes for each which are pretty easy drop-ins for the crossover design (again, with a few tweaks). For example, one could make a pretty good W(T/M)W center channel with the SB12CAC (little sibling to the SB15) and the RS150 (again, akin to the RS225). Or, substitute the RS270 for the RS225 if I want to turn it up to 11.
The crossover.
For now, the important thing for me is that I have a starting model for a crossover and a decent simulator. The "real"/final crossover design will need to wait until I get the actual drivers in and measure them, then put them in an enclosure in the room.
I've got a simulation below. It's second order except for the HF crossover to the mid, which is first order. I've put a "dummy" L-pad in the woofer section to simulate baffle loss since I haven't figured out how to integrate that into the response curve yet. 😆 Once I get the actual drivers, I can better match baffle step with the woofer/mid crossover.
What next?
My work plan is:
Mike (aka Cheesehead)
Objectives.
- I want the best set of speakers I can afford. Of course. 😉 I want to be able to listen to Elvis Costello, John Coltrane, Patti Smith, Norah Jones. I want to be able to play the Moody Blues "I'm just a singer (in a rock and roll band)" and hear the vocals on top of the guitar and bass line, without hearing them (vocals) breaking up.
- I would also like to have a design I can tinker with, with well-behaved drivers. I love to learn, and if there's a design that I can start with, model myself, and maybe make some tweaks, now I'm learning something.
- I would like to have a design that can be adapted to a home theater setting - center speakers, satellites. Having a set of similar drivers available which can be easily "matched" is a plus. Having a set that can be dropped into existing crossover designs with a minimum of tweaking is even better.
The drivers.
The crossover.
What next?
My work plan is:
- Decide on tentative design, including drivers.
- Put that design out for the diyaudio world for comment - am I missing something? Where I am now!
- Order drivers. I hope to do this next week.
- Measure driver parameters, import into VituixCAD for crossover design.
- Try the tweeter with a 3D printed waveguide and sim that as well - can I improve horizontal response?
- Enclosure design and build (tentative) enclosure.
- Install drivers and play with crossover design/tweaks.
- Tweak for compatibility with listening room.
- Build the "real" cabinet, with veneer and a nice finish.
- Listen and enjoy!
- Lather/rinse/repeat.
The 2 resistors in the woofer circuit shouldn't be there, they'll just waste power; the 2.49 resistor in the mids is problematic also,
remove them all to avoid amplifier problems. Of course, you will need to re-jig the values of the series resistors in the mids & tweeter as well.
Thanks, and agreed. That L-pad is a "dummy", only there to simulate the baffle step loss since I still haven't figured out how to integrate that into the frequency response curves in VituixCAD. The other resistor values will likely need to be adjusted once I have the actual drivers measured.The 2 resistors in the woofer circuit shouldn't be there... the 2.49 resistor in the mids is problematic also
As for the 2R5 resistor, again, agreed. The original Anthology crossover includes that component as 3R3. I figure I'll refine a little more (and increase the value!) once I get the actual drivers.
By way of comparison, here's the original Anthology design (with the SB15NRX2, not the NRX; speaker placement might vary slightly) with crossover. The L-pad which I added in the woofer circuit is there only to simulate the baffle step diffraction loss; in this sim I've disabled those resistors (shorted the 2R4 and opened the 3R5).
