my EL84 pre-amp with schematic
pleas comment on my schematic...
any problems????
should I increase the 150v?? maybe to 200v?
I want to use a regulated power supply (VR tubes) so thats why 150 was picked.
recommendations for power supply???
dunno about SS, hybrid or tube rectified..
Hmmmm....why so complicated?
Am I correct in assuming you're trying to make some sort of mu-follower combining a choke and FET?
Why not just use a choke as a plate load, take the signal off the plate and use a VR tube to clamp the B+?
You can use the loadlines from the 12B4A if you like, a trioded EL84 is very similar...Maybe wire it for ETM as well?
Zout would be in the 1K zone if that's what you want.
Cheers,😉
ETM?
What is ETM? and what is its advantages??
Do you think a choke loaded triode EL84 would "sound" better than a triode EL84 with a MOSFET source follower in a mu configuration??
Do I get any advantages of the mu over just a choke load??
Any PSU recommendations???
