I've been trying to design a PSU for a HifiBerry DAC+.
Since the feed point is (in fact) a decent regulator, I'm just trying to get the high frequency trash cleaned up, so I'm using a CRCRC circuit.
I was going OK with a simple SINE voltage source. Noise was down at -120Db at 1KHz. Voltage had minor ripple, but at low freq - that's what regulators handle really well.
But since I was concerned about the nasty wave forms that diodes can (I'm told) generate, I changed the input side of my circuit to have a SINE source representing the secondary of a transformer, and a bridge rectifier.
This simulates fine and reasonably under .tran, but under .ac the noise is now down at -540Db. Which is a little too good to be credible. Something's wrong.
I upgrade my LTSpice-under-Wine-Under-Ubuntu from IV to XVII (oops, version drift) with the same result.
I've attached my crazy sim run, and the asc file. Can anyone see what dumb-*** newb mistake I've made?
BugBear
BugBear
The simulation is only this, a simulation. Capacitors have certain amount of internal inductance, which resonates parallel at some well defined frequency. Above this frequency, the cap no longer behaves as a cap, more over it is inductive. Did you take this into account?
Classic sim user error.
.AC analysis is based on infinitely small signal exitation (read: linear behaviour everywhere) at the operation point established by initial DC conditions.
Also, you mus always use .opt plotwinsize=0 to avoid data compression.
Does that mean that (in effect) the signal isn't getting past the rectifier at all, and all I'm seeing on the output is noise?Classic sim user error.
I could understand that.
I shall go and look up what that means (since I don't know)
Thank you!
BugBear
Yes, actually you are only seeing calculation artifacts / resolution limits, not any type of noise (.AC analysis is noise-free). Your DC operation point is 0V, the diodes don't conduct at all. The scale value for an AC source is just that, a scale value. You can use 1uV or 100MegaV, it just scales the display. No actual voltage is presented to the circuit.Does that mean that (in effect) the signal isn't getting past the rectifier at all, and all I'm seeing on the output is noise?
.opt plotwinsize=0 switches off the file size compression of the output data used for display. Think sort of MP3 vs WAV.
For the new LTspice version it might not be needed to locate this statement in the sim file directly, I don't know, and I will never upgrade from IV...
Looks like you made a couple of rookie mistakes.
1. Forgot to select a diode model. Your simulation schematic shows that you used a diode called "D" ... which is an ideal diode and decidedly not available in the real world. I suggest you choose diode 1N4004 for simulation studies
2. Connected AC stimulus incorrectly. To get the answer you want, replace the input by two voltage sources connected in series. The first one is (7.5V DC, 0V AC) and the second one is (0V DC, 1V AC). This will let you get the answer you want in .AC analysis
Thank you. Does this mean I (in fact) need slightly different models for different simulations?
Is there an easy way to manage this, other then (re)editing the model for the two sims?
(I've changed the diodes as recommended; I wasn't planning to worry about component selection until I had the sims running OK; there seemed little point).
BugBear
Does LTSpice (version XVII) have any means of searching/filtering its component lists?
When I attempt to "Pick New Diode" I simply get an enormous unsorted scrolling list.
I don't think 1N4004 is there, but it's hard to tell.
BugBear
BugBear
1N4004 is not in the standard list.
Yikes, you're right. I've been using it for so long that I forgot I had downloaded it.
For those who want to simulate an 1N4004, Diodes Inc makes a SPICE model available on this web page -- look for the phrase "SPICE model". Or for those who just want to simulate with a real world 1 amp diode and find out whether 1kHz on the AC mains is (or is not) attenuated by 540dB, you can use the presupplied diode model of
- ES1D, or
- 1SR154-400
Here's what I get in AC analysis, assuming ESR = 50 milliohms and ESL = 5 nanohenrys.
The ultra low frequency response at the left edge of the plot is less than 0 dB, thanks to the voltage dropped across the two 1.5 ohm series resistors in the CRCRC filter. They form a voltage divider with the load resistor, guaranteeing that Vout < Vin.
_
_
Expanding the selection window and clicking on the column label should sort the list in order. I know it works for 'type' when I'm hunting zeners.
The column headings are only displayed when I changed the dialog size.
Possibly a small bug; I'm running under Wine/Linux.
BugBear
_
That's very much what I'm after; I'm trying to avoid feeding the Regulator the sort of (audio freq) stuff it can't filter out itself.
BugBear
It's only giving you about -30dB of attenuation at 2*f_mains, so I hope your downstream voltage regulator has good (~ -70dB) ripple rejection at 2*f_mains.
The spec sheet doesn't even bother giving a figure at 1Khz, but it's 70dB at 10KHz. 🙂It's only giving you about -30dB of attenuation at 2*f_mains, so I hope your downstream voltage regulator has good (~ -70dB) ripple rejection at 2*f_mains.
ADP150 Datasheet and Product Info | Analog Devices
BugBear
- Design & Build
- Software Tools
- My circuit is too good!
