My CDM1 Mk.II is finally fixed!, but now I have a question on the caps used
After living the last couple of years with disc initialization problems on my Proceed PDT3 transport I was fortunate enough to track down someone who had done a lot of work with these old Philips CDM mechanisms and had all the parts and test equipment to effect a repair.
In my case all that was necessary was the replacement of the caps on the servo board, and a realignment and refocusing of the swing arm and laser. I got it back and it works fine, but it doesn't seem to sound quite the same. Is it possible that replacing the servo caps could explain this? The originals were Nichicon VX types, which were replaced with Panasonic FM. I know that I shouldn't really make any judgements on sound until the devices are fully burned in, but right now I think I'm getting a slight bit of harshness. I did a bit of research and subsequently found that this is a characteristic of the FM caps, but would this be an audible effect from changing them in a servo circuit? If so I'm a bit worried. I was hoping to get my PDT3 repaired but sounding as great as it always did.
If this is due to these caps, is it something which will work itself out after device forming and burn in? Should I consider this an issue and look for which caps would be a better replacement?
