Hello,
Some pictures of my Aleph 60. The Aleph's drive a pair of Klipsch Cornwall with no bump, non hum, no hiss.... only Music!😀
Same data:
Power supply +/- 33 Volt;
Bias 2,4 A;
temperature rise of about 18° over the heat sinks😎
Ofset +/- 6 mV
The next step: Aleph P.
Thank you Mr. Pass!
Thank you Kristijan for the fine Pcb's.
Nat
Same data:
Bias 2,4 A;
Ofset +/- 6 mV
Thank you Mr. Pass!
Nat
Very nice job Nat.
Your construction is excellent. Tell us more on how they sound.
I'm wondering, what is the function of the 2 large 68ohm resistors?
Thank you Roddyama for your words,
the resistors are 0,68 Ohms and are in CRC filter arrangment.
They sond powerfull, deep, sweet and magic!!
Sorry for my bad english.....
Nat
Nat
Nat,
Nice job, well done. 😎
And about the sound of these ? I am also interested in the Pcb for CCS
for my X-BOSOZ
Alain.
for my X-BOSOZ
Alain.
Hello Alain,
The sound relaxed and very easy to listen. it's powerfull at the bass with a lot of details in the bottom end. The midrange is liquid and sweet with no grain. The top end is a velvet on my Klipsch. The image is liquid and plastic like a Leitz Summicron lens......
I'm Happy🙂
I'm Happy🙂
Eccezziunale veramente ! 😀
Very very nice.... where did you get those cases w/heatsinks (and how much did they cost?)
Cheers
Andrea
Cheers
Andrea
Hello Andrea,
thank you for your comment..😎
The case with the heat sinks is the model 04/400 from HiFi 2000 and it cost me about 125 €
He work great, at 2,4 A I can touch it with non problem.
Nat
Grazie😉
Nat
Grazie😉
Andrea, you can find it at www.digitex.it, under "contenitori per elettroniche" then "04/400 Pesante dissipante"
Nice work indeed, I can't use a similar case in my room, but all the work is amazing.
Congratulations!
Nat
Pardon my ignorance.
But aren't the 68 ohm resistors across the supply caps shorted out by the copper bar???- thereby effectively taking them out of circuit?? ie: no CRC
George
George
Hello George A,
the resistors are 0,68 Ohm and are mounted on a veroboard no on copper bar, so there is a crc. Every cap is 47000 uF, so there is 47000 - 0,68 - 47000 on plus and minus side.
Nat😎
Nat😎
a bit off-topic, but which turntable is that?
Nat,
Is that a Benjamin-Miracord turntable in the photo next to the reel-to-reel tape machine?
Regarding the amp itself, I like the power supply construction.
Erik
Nat,
Erik
Hello Erik,
the turntable is a Thorens TD 160 MK V S with a Mission Cyrus arm and the sweet Shure V15 IV MR.
Near the reel to reel tape machine there is a Philips DVD 963 SACD.
Nat
Nat
- My Aleph 60
