OK, I have checked the pin layout and find out that both BC 550 are inserted wrong. So I have turned them and try again...
Now the whole output part(fets and 3W resistors) is boiling. Literaly. When I turn it on it takes about 10 seconds before the heatsinks goes hot, hot, hot! What could be the reason? IRF9610 are only warm(working temperature).
regards,
DJG
regards,
DJG
Check you voltages across the source resistors if possible. If not check to see if you have a shorted Mosfet. Check the circuit around Q5, R17,18, and 19 they set the current. Let someone else take a look at it. It will give you a break and maybe they will find something you were not looking for. Good luck, Mike
Joined 2002
Hi, DJG
I'm happy, that you resolved the problem.
I just finished a tube preamp for the alephs (60), and sounds GREAT!!! Alephs needs preamp (this is my oppinion...), and a tube one makes the sound more warm and "sophisticated". You know what I mean... .
I will soon post a schematic and some pictures...
Miki.
Miki.
- My Aleph 5 isn't working
