My 3-way homemade speakers scanspeak
Homemade speakers
Alexya:
Since you obviously enjoy crossover work, I'd consider building them as external devices so you can showcase them in any future projects.
I'd also suggest you might consider carefully mounting those heavy wires so they don't put excessive strain on the connections to drivers.
Are these sealed, or vented? I'm surprised at your choice of random partial scraps of wood for bracing, and what appears to be random effort to seal seams. If it isn't too late, perhaps you could glue in additional pieces of wood?
Homemade Speakers
Hi Alexya
How do the speakers sound?
By using a cabinet and port from another speaker it is highly unlikely to be optimised for the 2 x 22w scanspeak woofers. That is the cabinet internal volume, diameter and length of port will not be suitable. You should get a lot better result with a cabinet and port deisgn specifically for these speakers.
Just checking, is the midrange Satori driver in a seperate enclosure inside the box?
Where did you get the crossover design from?
What make and model speakers were the original cabinets from?
Kindest regards
Richard
