ive had a few problems with the pitch control on my 1210,so i thought i would try and reset the 2 pitch pots back to "factory spec",first i looked at vr301,which i adjusted to "2.7kohm" that all went ok ,then came "vr301" under the platter,the reading i needed to get should have "262.08 kHz" ,the reading i got was about 140.00 khz , turned vr301 to the left as far as it would go,the reading went up but only to around 160.00 khz,anyone know why i cant reach "262.08 kHz" ??? any help is appreiciated
herman8r said:ive had a few problems with the pitch control on my 1210,so i thought i would try and reset the 2 pitch pots back to "factory spec",first i looked at vr301,which i adjusted to "2.7kohm" that all went ok ,then came "vr301" under the platter,the reading i needed to get should have "262.08 kHz" ,the reading i got was about 140.00 khz , turned vr301 to the left as far as it would go,the reading went up but only to around 160.00 khz,anyone know why i cant reach "262.08 kHz" ??? any help is appreiciated
vr302 is the first pot i looked at not vr301 my mistake
Hello herman8r,
Is that like Terminator or did you eat someone?
Go to this web-site: http://www.kabusa.com/
Email Kevin, info@kabusa.com, he knows these units like he designed them himself! He can most likely help!
Good luck!
Regards//Keith
Good luck!
Regards//Keith
