Hi All , new to the forums, but am very impressed with what I've seen so far. Had no idea there were so many audio nuts out there!
Anyway, maybe someone can help me...
I have two Musical Fidelity MA65 power amps, which someone gave me after he fried them. All that is faulty is the output transistors, which simply gone s/c . Now these devices are labelled A1000N & A1000P respectively. Now I got a set of replacements from MF cos these numbers just dont exist , very expensive they were too,£21 & vat & carriage for a set of 2!
Does anybody know what they really are (2N3055/2955?!), cos I need another 4 and dont want to pay MF's crazy prices. I have an MF E300 myself which uses transistors labelled F15N, F15P.
Guess what, when the first set of replacements arrived they were labelled the same.
So its clear MF use these trannys in lots of their designs, but change the labelling to stop people like me buying cheap replacements!
Any help greatly appreciated, thnx folks.
raymondo said:Hi All , new to the forums, but am very impressed with what I've seen so far. Had no idea there were so many audio nuts out there!
do you have schmtc for that amp?
(just because I'm not familiar with this model).
if conditions are simillar to A1 and A100,you can use 2n3055 and BDX18 (or 2955).
mebbe even MJ15003 and his brother 😉
If your's amps voltage rail are +-35 volts or less , you can use the "good old" 2N3055/2955 ...if the voltage is higher, then the MJ 15003/4 will do the job!
It's all semantics really.
Don't you mean his sister?choky said:mebbe even MJ15003 and his brother 😉
i have a set of 15003 and its sibling on the way
will try those,thanks
the rails are about +-43V. there is no bias pot in these amps, but god do they run hot, they are obv biased heavily into class A
will the new trannys be biased correctly.......?!
Is dificult to tell you...without the schematic...🙂
yes, unfortuntaley i don't have a schematic, if anyone out there does that would be great, MF won't give them out, even for old designs.
I'll fit them and see, should arrive today.
Thnx folks
Thnx folks
fitted the 15003/15004
amp is now working and sounds pretty good initally, i'll see how warm it gets during the day, and give it a proper listening test to see how it compares (i have another one with original devices in)
thanks again
thanks again
Re: It's all semantics really.
me thinks that SS is a gay world, and Tube is a straight.....
Circlotron said:
Don't you mean his sister?![]()
I use MJ802/MJ4502 on my A200 clone before, they work fine.
For your E300, if it is similar to E10, those MOSFET maybe IRF540/IRF9540.
Good Luck!
P.S. Do you have the circuit of your E300? 🙂
Good Luck!
- musical fidelity transistors....
