i have a problem
just spent all day seting up a Musical Fidelity Elektra Musical Fidelity Elektra E30 Power Amplifier Meridian speakers no matter what i tried with Speakers leads and phono leads i get a distushion through the left Speaker swaped the Speaker around and still the same help
Hi
If you give more information some people here might be able help you.
You need to isolate which component is causing the problem. Is it the speaker, or the speaker leads or the power amp left channel or the interconnect lead. You seem to suggest it is not the speaker - I think. Try swapping channels one component at a time to see which component is causing the problem.
If you can isolate the faulty component anfd then give some details of the damaged component then someonne here might be able to help.
Don
Don
