partially, check out the analog devices datasheet, and compare with mf's input.
I know the mf uses AD chips, ssm2019 and 2210 I believe.
also switchable iec, so my guess is they have used circuit 1 and tagged a bit on the end.
http://www.datasheetarchive.com/datasheet/pdf/22/2268.html
http://www.musicalfidelity.com/mf/en/Products/kW/kWPhonoStage
The first link appears to be down but i wonder how any of the mentioned chips achieves "Voltage RMS, maximum > 43 Volts "
no its definately better, scroll to the bottom of the page for a download...I think they use a discrete stage for the output.
try again this time 🙂...
The link works now. Very nice circuits indeed. What reasons do you have to believe any similarities? Pictures of the MF insides?
well I know the mf uses ad chips, plus if you look at the input design of the mf from their page
you will find its identical, so draw conclusions....
even pro companies use application notes....
The AD-page is very promising, but I don't see any MF input design to back it up. Where did you find it exactly?
I once had a Musical Fidelity Digilog D/A convertor. MF wouldn't give me a diagram, so I traced it out myself and found that it was a hotch-potch of IC manufacturers' application notes...
EC8010 said:I once had a Musical Fidelity Digilog D/A convertor. MF wouldn't give me a diagram, so I traced it out myself and found that it was a hotch-potch of IC manufacturers' application notes...
Well considering most DAC chips and DIRs nowadays are self contained this is of no surprise. Most just require a clock, data input and an IV stage. Unless you are going to use some complicated resampling or DSP to make CD a wonder format theres not much to a dac at all.
I bulit my DAC using tech sheets and MWP's shemematic, I could not be more pleased with the result, which is of no surprise considering the manufacturers are the people who are going to know how to make their chip work best.
Where I imagine most MF design comes in, is in the output stage and power supply. Nuvistas and choke regulation galore etc.
5th element said:... considering the manufacturers are the people who are going to know how to make their chip work best.
You'd think that, wouldn't you? But if you give it a little more thought, you realise that the circuits that the IC manufacturers are going to provide are ones that will work in any situation, not necessarily the best for a particular application.
hi Did anyone save that application note?
or which one was it, I have lost mine and will try to obtain it again.
The link doesn't work anymore, it hasn't for some time, I am convinced it is the musical fidelity, and they have tried to stop people from seeing it.
They are like that.
please reply, need to obtain again,
thanks
They are like that.
thanks
- Analogue Source
- musical fidelity kw phono schematic here...
