Musical Fidelity CDT Player
Hello,
I own a Musical Fidelity CDT Player. It has a signal transformer in the begining of the tube output stage (see enclosed pincture. It's is a cube shielded with a metal sheet). One channel fails.
Temporary I have solved the problem connecting the stage without the transformer. I have inserted one capacitor and one resistor (the signal was too high) in the signal path and the player works again.
I would be interested in the service manual of schematic.
Does anyone know the transformer specifications?. Does anyone know what is the CD mechanism?
Has anyone modified this CD player?
Thanks for your help.
No. I think the shielded "brick" has two transformers inside. It has only three input terminals and three output terminals. One is ground and is common.
My "brick" has one channel faulty. I have tested the other one connecting a sinus wave signal and checked the output with an oscilloscope. The output signal is lower than the input signal.
Maybe the only purpose of the transformer is to supress any DC offset.
Without the transformer and inserting a capacitor in the signal path (before the output stage), the tube oputput stage and the CD work.
Hello !
I bought this player and I like its vitality, I prefer it to my Arcam CD72.
It's hard to find informations on the Musical Fidelity CDT,
also known as 'Musical Fidelity PAN' (try this in google)
I do not know anything in electronics, but may be this link may interest you, or try contact 'dht' :
http://translate.google.com/transla...owe_cd_35158.html&sl=pl&tl=en&history_state0=
i speak english like a frog, sorry 🙄
contax,
unfortunately I dont have the service manual. I have only these two schematics posted on audiostereo. Maybe tomant could help you, send him a private message (PW) via audiostereo.
If you want to tweak the CD I suggest you to bypass the trafo and NJM4558 opamp. I can send you a LC7881 datasheet.
dht
Hi contax!
Do you solved your problem?
I have a Musical Fidelity "PAN" and my one has the same symptoms as yours.
Sometimes the faulty channel works fine.
When i heat up the "brick" it mostly works.
Can you help me?
Best regards
My solution was the supression of the transformer. I inserted one resistor and one capacitor per channel in the signal path. I didn't remember the values. I can check it.
I think the CD mechanism is a Sanyo SF-90 5/8. Does anyone know any details about the transformer?.
I often read it is a Sanyo SF-90 5/8 pin. There are several models of that player the one you (and I) have with the plastic lid is the older one, newer versions had a glass lid.
Mine has a spring loaded opening mechanism, I also read about hydraulic opening mechanisms (and their failures).
My CDT has a Sanyo SF-90 6/7 Pin laser pickup. Be sure to carefully check the pictures on the net before you get an exchange part, I got one from here: CD SF-90 6/7 PIN G?OWICA LASEROWA - www.100hz.pl
As for tuning, AFAIR the chipset used has an integrated oscillator so no clockupgrade should be possible.
All I did was to put textile tape to the places where the top covers touch metal supports.
As you can see here the mounting supports for the drive mechanism in my player are not black, I covered them in black textile tape where they are visible from the outside.
My CDT has shown another problem, the paint/coating gets off of the two top plates when cleaned. I have to see how I can solve that, but I would be careful (the first spots of colour got off when I had them in my ultrasonic cleaner).
Regards Tom
