Sorry but have given considerable amount of advise already and I'm guessing that you don't have much experience of this sort of work..... i can't talk you through every possible reading on every possible component.
Last bit of advise..... try lifting one end of R61 and R62 (both 4R7). If everything stays cold now then that proves that the output stage and psu are ok.
hello.
is it only one channel that burns the resistors?
can you measure the res around the drivers and predrivers,with a multimeter?
greets
not sure what predrivers are? I'm going to order new BD140 BD139 x2 see if that works!
I know this thread is a bit old but I ask:
did you then solve the problem of r68 smoking?
- Musical Fidelity B1
