Musical Fidelity A100 problem.
Hi. I've read loads on here about my amp and as a result, collected all the parts I needed to overhaul it. But then it started misbehaving. First it cut out but then was okay again after I left it to cool down. Then it made a horrible load hum - so loud I instantly turned it off. I decided to replace all the electrolytics, including the smoothing caps, with 105 degree versions. After this I briefly powered it up with the lid off and the hum remained. Not only that, R2 (0.47ohms, 3w) glowed red hot.
So I replaced al four power transistors and the four drivers too. Plus the four zeners. But the problem remains. Any ideas what I should try next?
Thanks.
