Music Angel KT88 correct circuit
There are a number of smaller differences between different deliveries of these amps, so the best method to get a circuit diagram that is correct for your amp is to mark up your own version of the diagram.
If you feel competent to improve the internal circuit, you should also be able to correct the published schematic - with a little effort..
The 6n1 tubes can successfully be replaced by ECC85.
The common of the OPT is grounded since the amp applies some (moderate) GFB.
If you operate in triode mode you can disconnect the GFB if you want, and make the output floating.
Here is a link to a diagram I helped a friend to mark up for an amp he had got early this year: Music Angel: DIY Skjema for MA KT88
Your amp may be different.
Svein.
Can be considered ok this wiring modification for a god listen ?
Paolo
