I'd like to have more than one Tape Out from my DIY preamp to connect to a couple of tape decks and one for connection to a headphone amplifier.
They would be taken from after the input selector (and unity gain buffer) and before the volume pot.
Do I need to include something like series resistors or can they be direct feeds to each deck/headphone amp (only one will ever be used at a time, but it saves plugging/unplugging connectors).
If the wiring outside the set is long, cable capacity will load the amp worsening high frequency response. Then, a buffer prior to the output signal is a good idea (Not more than a follower, perhaps an opamp wired unity gain).
When I built a 23-output distribution box for live concerts, I put series resistors in so that one shorted load did not kill signal to all loads. (One professional suggests that with up to one-third of loads shorted, signal to the remaining loads should not be significantly degraded, he must work in a tough place.)
Three loads at home, I would just use Y-adapters.
I would suggest simple signal switch instead of Y adapter. Having signal going to 3 inputs at the same time, while only one is powered, while others may be turned off is problematic. You may pick up some hum or buzzes.
something like this...(but not 10x overpriced)
Vintage Akai DS-5 Tape Deck Selector Tape Switch Black USED Japan | eBay
