Multiple Small Subs - Geddes Approach
Yes, that works too. But being active makes for a headache (power supplies, grounding, etc.). I like passive whenever possible because of less potential for problems.
You could use Y-RCA's if you used padding resistors. Since the DCX has so much gain, this might work fine.
markus76 said:
Which box are you talking about? The BassQ? Didn't you read the manual?
"Although the
system has been designed to work
with the rest of the Performance Series
system, including AV1 and AVA7,
the unit can be used in almost any
system and can improve the in-room
response of almost any installation."
"There are two subwoofer inputs.
If using an AV1 processor or other
processor that has a single subwoofer
or LFE output
, connect the subwoofer
output to the Left input and set the input
mode to Mono on the front panel of the
JBL BassQ unit. [...] If you are using
a preamp/processor such as the AV2,
or an AVR that has stereo subwoofer
outputs
, connect the left and right
inputs and set the mode to Stereo on
the front panel of the JBL BassQ unit."
But you still don't have the LFE in the speakers.
What more proof do you need than real world data I posted??
Markus
Markus
Your data didn't prove a thing. Only that there was LF output in the center channel NOT that it was any different than what was in the left and right.
And when you set the AVR to "NO Sub" then the LFE is sent to the mains and hence gets to the DCX.
The JBL box REQUIRES the same signals as the DCX period.
amiklos said:
I have a hard time believing that there is much unique LF content sent to those surround channels, at least not enough to justify the complexity of the system being suggested (yes I saw Markus's data). While in theory there may be something that gets missed, what is the practical impact in the course of 99% of listening? Studios aren't really expecting the average consumer to have 5hz-20khz reproduction on each channel are they?
Even if you did want to combine all the LF info from all the channels, what prevents you from using a mixer to sum sets of channels ahead of the DCX rather than needing several DCX units? The goal is still to send the same LF info to all subs (with requisite processing in place), correct?
Your right, I had misunderstood what was originally being suggested. I thought something else was being suggested, but this all makes sense.
So what you're basically saying is "Yes I saw the proof but I'm ignoring it and state the opposite". Admittedly one DVD is not representative but I'll definitely check more DVDs in the future. And there will be a lot of thanks to Netflix.
Best, Markus
This is an example of a simple unbalanced to balanced circuit. If you look at the first opamp, you can add the L, C, and R inputs to tag two by having each one have it's own 33k padding resistor. Then all would be combined with no cross talk issues. While it's not necessary, and if you had to buy it, I wouldn't recomend it, you can make it with 3 single opamps (or two duals), and have the benefit of a little lower noise and no cross talk issues.
I've not used this DCX device, but I did use the older DEQ eq unit, and I had so many problems with it. The huge amounts of gain as well as the passive unbalanced to balanced and back again caused a lot of hiss. I think using this mentioned device would fix that maybe, but I would need to pick up a DCX and try it.
Best, Markus
I'm saying, "I saw Markus show that there was LF content". You didn't show unique content, and I made a point of noting that in the comment you quoted.
Your tone has become quite combative lately. I'm unclear as to the cause.
Are you sure about that? A few posts ago you were sure that there is no low frequency content in the center channel at all. I feel better by looking at facts and real world data instead of adopting a belief.
Even if the low frequency content in each channel is the same, you might end up with the bass level being to low because you ignore the signal from C, LS, RS, LB, RB.
That's correct. But what if the audio engineer decides to mix some low frequency content only to L and R? 3 to 5 of your sources will drop out of your low frequency array.
As I said before I don't know what the BassQ does so I don't know what signal is best. I don't want to promote that box in any way. But the manual is pretty clear that you simply need the sub out which is available from every AVR.
Best, Markus
Best, Markus
Isn't that because it's a different approach which promotes high passing all speakers and not using them as additional LF sources.
I do think there is a problem with highpassing. In my opinion, based on my understanding of LF small room acoustics, you really want to deal with the LF problem at the transition point. That means either removing the mains from the LF equation completely or replicating the LF content across all the LF sources, including the mains. Highpassing the mains doesn't do the same thing as replicating the LF content across all LF sources unless it's high enough in frequency.
Markus
Now that I've had a chance to rest, I'll come back to your discussion.
First you have to understand that in "No Sub" mode all LFE is routed equally to any speaker that is "large". If the surrounds are set "small" then their LF signals are likewise routed to the "large" LCR. Now in the DCX, if the LR signals are summed then ALL LF content is present, EXCEPT any LF content that is unique to the center channel. I claim that this "unique" center LF content is non-existant, but very rare at the outside - it will always be the same as the LR LFs. Hence, there is no LF signals that do not get to the subs.
Now a question that you asked before IS very relevent. When setting up the subs, does the "main" signal contain the center channel or not. THAT is a relavent concern since it can't be done both ways. I haven't even tried it both ways. I optimized for stereo by using just the LR signal in the "mains" signal. When there is a center channel then its like adding a sixth sub to the mix, and I don't expect that this would yield a very appreciable difference. Certainly not one that I have ever detected.
Earl,
that's all correct and there's an additional problem: uncorrelated low frequency content in only one or two of the 3 front channels.
<broken record>Apply a highpass by running all speakers as "small" and optimize the AVR's sub out. This will deal with ANY source signal and any cheap AVR will work.</broken record>
Best, Markus
markus76 said:
Earl,
Best, Markus
Don't you then lose some of the advantage of having some upper bass from the Summa/Nathan/Abbeys?
randybes, to a certain extend you will loose the speakers as additional low frequency sources, yes. But you'll gain a controlled setup that works with any source material and is simple to set up.
The real question would be: are three subs enough?
Best, Markus
Markus
"an additional problem: uncorrelated low frequency content in only one or two of the 3 front channels"
Except that I don't agree. That is ONLY true if its the center channel and there is a trivial solution - just sum ALL three channels. If all three front channels are summed then it makes no difference if the signals are uncorrelated or not.
Running all speakers as "small" adds nothing but looses the multiple sources from the mains.
I simply do not agree with your assesment.
You made that more than clear. But you still have a problem if there's bass on only one of the front channels. Under that circumstances 2 of the 3 front channels won't act as low frequency sources anymore. We both don't know if this is a real problem because there simply is no data. My conclusion is to use a setup that can handle any source signal—high pass filtered mains and surrounds.
Best, Markus
In wanting to do this method, I do have one unique problem (not a major one) in that I use a Pre-pro with separate amps, not a receiver. I only have the one set of pre-outs for surround, but I realized that I also have 2nd room pre-outs which are a 2-channel mix down. Can anyone think of any reason why this wouldn't be the perfect solution for me (I'm assuming it mixes all of the channels including the LFE into the 2nd room output). If I'm thinking correctly, not only do I get to hook up without using y-adapters, avoid any chance of channel separation issues, but also would deal with the problem Markus brings up.
Markus, I saw that you tested the signals before, if you want to see if your concern is warranted, why don't you look at the waveform of all the channels during the same parts of the movie. If that doesn't come up with anything, look for parts with hard effects steering, and then see if the LF content is different.
What problems are you having with the DcX? As I mentioned earlier, I had some horrible issues with the DEQ, and I've been reluctant to ever try one of these devices again because of that. There was simply no way for me to get it balanced right without causing such low input levels as to cause "loss of bit resolution" causing the onset of audible distortion during low level signals. It introduced a ton of hiss that I simply could not get rid of no matter what I did. While I would like to try this device, and I have used really good DSP devices from more expensive companies, I'm still really reluctant to use this one.
pjpoes,
I would love to take a closer look at multichannel signals but haven't found an easy way to do it yet.
I own a DCX and use it in my 2 channel setup now for years.
The DCX has basically the same problem as the DEQ has. It's built for PA and not for home use. The max. input level is 22dBu which is much more than consumer electronics can deliver. You will "loose bits". If you're running the DCX behind the volume control then you'll further loose bits. But there are 24bits@96kHz so this might not be a problem at all.
The hiss was probably not a problem with the unit but with unbalanced cabling. That's why I run my whole setup balanced. Hiss can also be caused by a hardware bug of the DCX. It becomes audible only when using the digital in.
Best, Markus
