Ok I have 2 display card in my PC, primary to the monitor and secondary to the projector.
The problem is, when dragging the DVD video window (PowerDVD) from the primary (which it shows perfectly ok) but blank in the secondary display (projector) ?
anyone has any idea why? Thanks
powerdvd will only show video on the primary display. It has to do with the video overlay. if you go into the advance options for your video card you can choose to have the video overlay mirrored on both monitors. Or you can just switch the projector display to be used as primary when you want to view a movie. I use Zoomplayer which does not have the overlay problem.
Rekr
Rekr
