Why would you want to?
Resistors are really cheap.
Unless you have some Vishay S102s that you want to try.
Not knowing the application.......you may want to isolate the chips to prevent current hogging. Can't do that with one feedback resistor.
Jocko
Jocko
This is for a BPA200 Bridged/Paralleled Circuit using the LM3886s.
My question was, WHY can't I do it with one resistor?
Re: Why would you want to?
Where can I get cheap .1% metal film resistors?
Jocko Homo said:Resistors are really cheap.
because of process variations no 2 chip amps will have the same open loop gain or offset voltage
with one feedback R you only have one input voltage to feed to the paralleled chips, I doubt even chips that were adjacent on the same die would match open loop gain to 10%, then add gain and offset tempcos with inevitable heatsinking variations and thermal runaway is highly likely
chip amps are designed to be used with negative feedback, the designers go to no effert to make open loop gain stable or to match between devices, high gain is the only goal
cheap digital multimeters are adequate to select 0.1% matches from a large number of 1% Rs - the measurement doesn't have to be accurate, only repeatable
jcx said:cheap digital multimeters are adequate to select 0.1% matches from a large number of 1% Rs
How please?
leadbelly said:
How please?
i think he's trying to say that if a meter is accurate to 0.1% (which cheap ones easily will be), you test resistors to the exact value you need. for instance, a 100ohm resistor that tests with a meter will be 100ohms, +-0.1%. you can get cheap 1% or 5% resistors, buy more than needed (like 10 times or so), and sort them out. ive noticed that some dale or vishay resistors that are 1% test very close to 0.001%. i bought 5 times what was necessary and got more than enough of 0.0001% resistors (thats the limit of my meter).
cowanrg said:ive noticed that some dale or vishay resistors that are 1% test very close to 0.001%. i bought 5 times what was necessary and got more than enough of 0.0001% resistors (thats the limit of my meter).
How are you getting numbers like this? Are you testing with a bridge?
hum, i dont know what you are asking... its quite simple...
if your meter is within 0.001% accuracy, and it says that its exactly 100 ohms, then that resistor is 100 ohms, +-0.001% accuracy. simple as that. so buy a big batch, test them individually, and use the highest accuracy ones.
at www.reichelt.e search for "MPR 100K"
or
http://www.schuro.de/preisl-cmf-55-1.htm
http://www.schuro.de/preisl-491-0_01-1.htm
what is cheap?
Or its a 100 Ohm resistor and you measure it and it measures 99.9998ohms and another measure 100.003ohms, so then you just meausure another one and it measure out to 100.002ohms, so now you have two that are very close.
Is selecting four equal values out of a bunch really what's needed here?
Doesn't Xplod actually need four voltage dividers of the same accuracy?
I don't have the schematic at hand...
cowanrg said:if your meter is within 0.001% accuracy, and it says that its exactly 100 ohms, then that resistor is 100 ohms, +-0.001% accuracy. simple as that. so buy a big batch, test them individually, and use the highest accuracy ones.
Hybrid fourdoor said:Or its a 100 Ohm resistor and you measure it and it measures 99.9998ohms and another measure 100.003ohms, so then you just meausure another one and it measure out to 100.002ohms, so now you have two that are very close.
What measument devices are you guys describing that provide so many digits of information?
cowanrg, if you had a digital meter reading of exactly "100" ohms in so many digits, then you have measured that item to between 99.5 and 100.5 ohms.
- Chip Amps
- Multiple chips, one feedback resistor
