multiple bass shaker amp
Hello all, I am going to be driving 6 bass shakers in some sort of series /parellel circut. Now I know they (aura) say's 25w a piece is plenty, but what about 6? I am figuring on an plate amp for this. Cheap me, says 100w unit. Sencible me, says 250w. Real me, says 350w. Who is wright? Thanks Jimbo.
sub subwoofer?
Aura Bass Shakers closed out at about twenty bucks.
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=299-027&ctab=10#Tabs
What would be the result of using a couple of these is some arragement that would induce low freq? Is is conceivable?
Mounting them on a 3X3' sheet of steel under the floor joists or mount them on an oak board, permanently mounted somewhere and tuned by length perhaps to a desired resonance?
Just a crazy thought.
just to clarify the above a little. Is it reasonable to think that such a devise, properly applied, would produce frequencies reaching even a little bit into the audible range? If so, how would the performance in those lower freqs compare to a traditionally built subwoofer?
