Hello to all, I posted in the Musical Instrument forum yesterday inquiring about a new or upgraded multimeter, got no responses, shoulld have posted here, please give a look and a reply, Thanks again, Genmin
I just got a Fluke 287. Not cheap but Circuit Specialists is running a special giving about $150 off on them, plus they throw in a free cheapo meter (www.CircuitSpecialists.com)
Protek is not bad -- much less expensive than Fluke but not same quality. I like mine except for a kind of dim display with an easily scratched cover and a puny-sounding chirp when doing continuity checks. I think it was about $150 a few years ago. http://www.protektest.com/main.asp
Joined 2003
If you want something that is going to last forever, look at Fluke. They have the best reputation, rarely need to be calibrated, however the cost reflects that. I have a Fluke 179, excellent multimeter, however cost is about CAD$300.
If you're looking for something that works well on a budget, I'd recommend a Greenlee meter.
Bench or portable, do you have any desired features? What's your intended use?
I haven't seen a broadband AC meter for less then ~$300 or so, most roll off above ~5000Hz and below ~40Hz.
Flukes are very durable - the sales reps sometimes demonstrate by measuring something, then throwing them across the room, picking them up and measuring again...
