Look guys, it’s a real thing. “SparkFun offers the Mooshimeter, a multi-channel multimeter that harnesses a smartphone or tablet’s hardware as a wireless, high-resolution graphical display using Bluetooth® 4.0. The Mooshimeter is able to safely measure 600 V at 10 A with 24-bit resolution from up to 50 meters away making multi-channel measurements possible in situations that are too fast, too slow, too sensitive, or too dangerous to use a traditional multimeter.”
It doesn’t make any sense in your example, but there could be situations where it would. Personally, in my advanced age a large ‘analog’ display would be quite helpful.
Thanks for your patience and the link.Sometimes it is important to understand where people come from, what their expertise is, before you can give a sensible recommendation.
If you don't understand how resistance measurements work, it will be hard to judge the merits of a specific reommendation.
I know you know that to measure an R you use two probes on the R and read off the resistance, but that is not the question.
Anyway, I'll bow out now. Good luck.
Jan
Please put a link with this multimeter from spakfun.Look guys, it’s a real thing. “SparkFun offers the Mooshimeter, a multi-channel multimeter that harnesses a smartphone or tablet’s hardware as a wireless, high-resolution graphical display using Bluetooth® 4.0. The Mooshimeter is able to safely measure 600 V at 10 A with 24-bit resolution from up to 50 meters away making multi-channel measurements possible in situations that are too fast, too slow, too sensitive, or too dangerous to use a traditional multimeter.”
I looked it up, Digikey is indicating mooshi obsolete. I also looked at the datasheet still available, and they specified no accuracy spec. so not sure how accurate the thing was. I have a harbor freight DVM, I trust it to about 1% on voltage and 5% on everything else and it is still useful sometimes with that level of accuracy. But if I fry it, oh well. I think it was 7.99 I have a much more expensive B&K I use for more accurate work. I'd expect the mooshi is more like harbor freight accurate.
The purpose of the Mooshi is not accurate measurements but totally isolated/floated measurements.
I use it to measure Vgk in a cascoded 4kV HV amp, for instance. The whole thing sits at 2kV.
Jan
Jan
Sounds like a good application for it, digikey had a photo and it is battery powered so completely floats. Someone posted 24 bit resolution. No way it is 24 bit accuracy.
https://www.digikey.be/en/product-highlight/s/sparkfun/mooshimeter-the-smartphone-multimeterPlease put a link with this multimeter from spakfun.
Go to about 50 seconds for the Mooshimeter:
No not 24 bit resolution, it has a 24 bit ADC. I don’t think that relates to accuracy or precision. The marketing guys put that out in the advert.Sounds like a good application for it, digikey had a photo and it is battery powered so completely floats. Someone posted 24 bit resolution. No way it is 24 bit accuracy.
Edit: they are claiming 24 bit resolution, I don’t thin it means what they thin it means.
link: https://moosh.im/mooshimeter/
“Why 24-bit Resolution?
In the world of DMM’s, precision is usually given as a number of digits. The cheapest meters are usually 3.5 digits and carry a 12-bit ADC at their core. An entry level professional meter will usually be 4.5 digits and have a 16-bit ADC internally. The Mooshimeter reinvested the money saved by dropping the display and interface hardware back into the measurement components and is built around a 24-bit ADC. This gives you up to 7 digits to work with, though for most measurements expect 5-6 noise free digits. Combined with the graphing capability of your smartphone, this allows you to pick up the smallest and most subtle signals.”
I’ll settle for some beer and Cheeze-its. 😋I think someone needs a valium and a hug.![]()
Here is a pen like meter (Pokitmeter) that claims to have O-scope capabilities.
https://shop.pokitmeter.com/collections/home-page-showcase-products/products/pokit-pro
Yep, there's also the linearity issue too and sample rate/count isn't mentioned, nor is the noise floor (other than a statement about digits of other devices).
I have a Brymen 869s which is 5 digits on 500,000 count mode, and built a 24bit ADC with a 5572.
Yes having a nice UI is great.. but in the end I like my Brymen because it takes two seconds to setup I can read it from meters away and it seems bullet proof - regardless if I'm measuring LDO regulator drift at sub 1mA or meaning tube amp B+. It also measures a signal up to 100KHz which means I can trace a signal with it without a scope. (it's also been shown to survive it's rated 1KV, over voltages of 5KV and 15KV with a diode replacement)
It may be a great device and provide insulating distance but it needs some "testing" before it establishes a reputation to replace the Brymen 😀
- Design & Build
- Equipment & Tools
- Multimeter App
