Hello.
I´m new with multisub approach. I would like to optimize the setup with MSO app. I´m using DBX DriveRack 260 which is similar than Behringer DCX 2496.
Do you know if MSO app is compatible with DCX2496 and/or with DriveRack 260 or is compatible with the MiniDSP only?
Thank you in advance! 🙂
Try and watch this video:
YouTube
He starts to talk about the optimizer software around the 16 minute mark.
Thank you for the link, it´s a great video.
Thanks a lot to Dr. Geddes for the presentation and his knowledge he´s sharing.
Did anybody try REW´s room simulator and implement it´s data (delays, phase, etc.) to his own multisub setup?
I would recommend that the Multi-sub Optimizer software NOT be installed! It is extremely convoluted and difficult to use. Then when you uninstall it, it leaves a trail of mess in the Windows Registry that CCleaner can't even fix. It screws with shell integration and leaves a stupid Multi-sub_opt option in the right click / New context menu even after uninstalling and requires manual editing or the registry to fix. I spent days trying to figure out this mess of a software package and longer fixing my desktop afterwards. Be warned!
Yes.... it's a rather complicated piece of software, which Geddes tried to help with - but somehow the guy behind the software declined.
I find this by Geddes to be an easy way to set up subwoofers:
http://www.gedlee.com/Papers/Setting%20up%20subwoofers.pdf
And to uninstall software.... this seems to be good:
IObit Uninstaller - Bedste gratis afinstalleringsprogram til din Windows XP/7/8/10 pc
It looks like the registry problem is now fixed.
- Subwoofers
- Multi-sub optimizer
