Mullard 12AU7 tests bad when running grid leakage test?
May be noisy, although whether this is noticeable depends on where it is used. Grid current may cause distortion if fed from a high impedance - this is a separate effect from the distortion caused by wrong bias.
Unless this is being used in a non-critical position (e.g. cathode follower) I would bin it. Alternatively, if this valve has been sitting in someone's cupboard unused for 40 years then it may improve with use so use it, then test it again in a few weeks time.
