MTX Thunder 81001
Do you have another pic of the area around FET401 Its right next to
Fet192..
Also a pic of the other side of the board around the rectifiers ?
Someone has worked on this before and wanna make sure they are the correct parts that are in it..
Fet 192 and Fet401 are 540's correct?
I think FET401 is an N-channel FET but I'm not 100% sure. FET 192 is a 540.
Ok will do..
Hopefully all the right parts are in this amp someone has worked on this before and has been all over the board..
The amp i have here Fet192 Fet401 Fet191 all have IRF540's in there locations..
Also i rebuilt the area around Fet192 Replaced all resistors transistors and the regulator..
As soon as i powerd it on the fans spun for 1 sec then Q109,Q111,D105,Q108 all failed again..
Q405 is marked C1U5A in this amp..
Cant find a data sheet on it but heres the reading i get
Top pin to left bottom pin :OL
Top pin to bottom right pin:OL
Left bottom pin to right bottom pin:0.015
Probes reversed
Top pin to bottom left:0.644
Top to bottom right:0.622
Bottom left to bottom right:0.015
Defective ??
I THINK that part is OK.I have 3 of these amps here with blown power supply's and thats the same reading I get on all of them for Q405.They also test at about 25 ohms on pins 1&3.
And yes one of them I have is also marked C1U5A.
Does R417 test good?
The voltages on the 2 op-amps are
Pin 1:-6.46
Pin 2:-13.32
Pin 3:-13.25
Pin 4:-14.95
Pin 5:-6.75
Pin 6:-79.8
Pin 7:-7.62
Pin 8:15.74
Pin 1:15.47
Pin 2:14.03
Pin 3:14.39
Pin 4:-14.39
Pin 5:14.52
Pin 6:14.01
Pin 7:14.96
Pin 8:15.93
Voltage across opto-couplers
Pin 5 to 8:18.04
Pin 5 to 8:15.99
If i use ground terminal as reference for the opto-couplers i get
Pin 5:4.16
Pin 8:-63.1
Pin 5:-81.2
Pin 8:-65.3
I notice something in the power supply cycling i can hear a small squeak .. When amp is powerd up i get 81 volts across the output terminals ...
If i leave the amp idle for a lil while once i hear the squeak the voltage will drop to 4.25 volts across the outputs for a few secs the it will go back up to 81 volts..
The amp does this over and over
