MTX Thunder 5601 burnt IC
Good day guys, I have a MTX Thunder 5601 on the workbench but I can't seem to identify the part number on a particular IC. With the cover off and all connectors facing you the IC is on the extreme upper left side, I didn't remove it yet to see the board location number as its gonna get crumbled and so far I can id some letters and numbers on it. I've also post a pic to get a better view of my problem.
Im currently repairing the daughter board (audio/function) and all the low ohms current limiter resistors are gone, i wont debate over the op-amps (TL074) ill just change them all, i have also puffy 50v 10uf caps on the op amp rails.
One of my main proble now is transistor Q200 (seems like KB) is burnt, can i get the equivalent or a likely replacement for that transistor?
***On the main amp board, the two largest smd cap marking 10 KFK 5K0 does that part is 50v 10uf?
