MTX Thunder 1501D
I have an older version of this amp .
I’m going to to use the 3205’s in the power supply section .
Does anyone know the value of the 2 gate resistors R436,R435 ?
And wondering what outputs I can use in this since I can’t find the originals the originals are IRFB42N20D
Here is the drive signals for the power supply fets .
They are loaded with a 0.1uf cap scope set to 5us 5volts/div
Do these look fine or do I have an issue ?
Class D chip? U141 is a VCA (Voltage Controlled Amplifier). It has nothing to do with class D amplifiers.
Is the 1k resistor between D198 and D199 within tolerance?
Are you using a signal source with a grounded shield?
Are the RCA shields securely connected to the RCA jack frame?
Side note, leave the burned diode out of the circuit.
If I use main ground terminal I get 0.53 volts on pins 1,7 of the TL072’s
If I use rca ground I get 0 volts
If I use main ground on pins 1,7 of the NE5532’s I get 15.41 volts
If I use rca ground on pins 1,7 of the NE5532’s I get -14.86 volts
I have +- 16 volts on the supply pins for the opamps
My mistake if I use main ground on the NE5532 I get -14.85 volts
If I use rca ground I get -15.41 volts but only on 1 5532
All of the other opamps read the same no matter what ground I use the most voltage I get is 0.54 volts on pins 1,7 of all opamps .
I think the problem is with the optocouplers.
Here is the voltage on both of them
Pin 1:0.00
Pin 2:-0.06
Pin 3:0.00
Pin 4:0.00
Pin 5:0.01
Pin 6:6.87
Pin 7:7.04
Pin 8:19.26
Pin 1:0.00
Pin 2:0.00
Pin 3:0.00
Pin 4:0.00
Pin 5:-78.4
Pin 6:-70.4
Pin 7:-70.4
Pin 8:-58.0
