MTX TA 81001
This amp powers up but doesnt produce audio..
Reading some other threads i got some info on the amp..
Heres what i have on the OP-AMP closest to the OPTO_COUPLERS
Pin 1:-13.91
Pin 2:0.23
Pin 3:0.08
Pin 4:-15.50
Pin 5:-13.62
Pin 6:0
Pin 7:14.23
Pin 8:15.05
I have Positive 81 volts of rail and negative 82.2 volts of rail..
I also have + - 15 volts of regulated voltages on the op-amps..
I also have audio on the 2 large SMD Caps near the RCA Jacks C306 and C307
The other thing i noticed is theres no voltage on the gate legs of the power supply fets ..
Any suggestions ?
This power supply drive the FETs differently. You can't use voltage to troubleshoot it. If you have the tutorial, read the 'MTX Power Supplies vs Other Amplifiers'.
The op-amp appears to be defective but the input is very near the supply voltage so the output may be inverted from that and may not actually be defective.
Ok replaced the op-amp with a brand new one ..
Heres what i have now..
Pin 1:-13.64
Pin 2:0.14
Pin 3:0
Pin 4:-15.44
Pin 5:-12.49
Pin 6:-11.44
Pin 7:-12.58
Pin 8:14.99
Still no output..
Is Q405 (C1URA) a muting transistor) if so can i pull it to see if the amp has output or leave it alone ?
