MTX MiTEK Thunder4250D blown
if its the big large amp, i think the last one i worked on was a 6500D. it had similar issues, one shorted output, blown gate resistor, and all 8 power supply transistors were blown.
I used a 73343 to replace the 73335, which are the same thing, except the RDS(on) of the 43 is much lower, making it more efficiant, less heat. worked better.
I got away with replacing the single output in that one also, and it worked fine. no issues out of that amp. just this stupid amp i got here now....
It looks just like a 421D that I have. I marked the pic with the parts that were bad on mine. The three caps on mine were bulged and the two smaller ones that flank them were blown off the board. The opamp was the main cause of my output problems.
cory
