The mute pin is always having 3.6v when remote signal given reducing to 3.2 but coming back to 3.6v. And no oscillations on outputs.Are you saying that the mute line is remaining at 12v and never drops?
Oscillations starting but then soon disappearing. I am not seeing anything wrong with remote line. Mute pin suppose to go to 0v to enable drive signal right?If you have something dragging the remote line down, that's something that you'll have to find.
OK. You were saying that the mute like was dropping from 3.6v to 3.2v when the remote voltage was applied to the amp.
Without remote, the mute should be near 12v. When the initial mute delay ends, the mute should drop to very near 0v.
