MTX 8302 problem
Been playing a little Miles Davis for about 15 minutes into a bridged load.
What I don't understand, is why there was so much voltage present at the output jacks, but it's not blown outputs?
Was this strictly a DC offset problem because the omp amps weren't operating? Or was this amplification of DC offset of the op-amps?
I use a 2N6488 and a 2N6491. The Digi-Key part number is HS121 for the heatsinks.
If you do this...
Clean the pads with desoldering braid.
http://www.bcae1.com/temp/mtxregmod8302/IMG_8940b.jpg
Bend the legs as shown and make sure that the legs don't contact any other traces or components.
http://www.bcae1.com/temp/mtxregmod8302/IMG_8942b.jpg
Install the heatsinks (with heatsink compound).
http://www.bcae1.com/temp/mtxregmod8302/IMG_8945b.jpg
Use a piece of stiff cardboard, or fishpaper (preferred) to help support the regulators (to take the stress off of the pads). Make sure it goes to the board between the diodes.
http://www.bcae1.com/temp/mtxregmod8302/IMG_8946b.jpg
Apply adhesive to the point where the top of the sink meets the fishpaper. Make sure you don't get any on the transistors.
http://www.bcae1.com/temp/mtxregmod8302/IMG_8950b.jpg
The fishpaper needs to be just short of contacting the cover.
http://www.bcae1.com/temp/mtxregmod8302/IMG_8954b.jpg
Glue a piece of closed cell foam to the cover so that it applies pressure to the fishpaper when the cover is replaced.
http://www.bcae1.com/temp/mtxregmod8302/IMG_8955b.jpg
