with the black lead on the main ground coming into the amp and the red on the pins i got...
location U300
4. 29v
11. -.5v
U401
4. 29v
11. -.5v
but the pin 11 on both are moving around from 0 to -.9v neither is static like the 29v
and i keep getting the 1k resistor (R502) so hot it keeps melting off the board.
location U300
4. 29v
11. -.5v
U401
4. 29v
11. -.5v
I've been using photos that I have of an 8001 since they were more complete. It appears that the amps are similar but there are differences. In your amp, the diodes in your amp are likely D400 and D401. Your amp doesn't have the capacitors. When you power up the amp, do any of the op-amps get hot?
oh good i was afraid i was possibly wasting your time by not being able to find the components.
D401 is 35k ohms both directions and D400 is 50ohms both directions. that is tested in the board i can pull them if need be.
yes 2 op amps are getting hot. U502 (LM311) + U501 (NE5532D)
sorry, you were right i had pos and neg mixed up coming into the amp. i have +-46v at the regulators now
both controller TL074C have +-12v now
i have 46v at the #4 +VCC pad of the missing op amp and -33v at the #8 VCC pad of the other op amp.
i have the 4 ohm 40 watt resistor inline in the B+ terminal.
- General Interest
- Car Audio
- MTX 6001 (red protect light)
