MTX 1501D
This had a blown power supply and all of the outputs were in tact.
I replaced the 39R2 resistors and all 8 75339ps. It powers on an oscillates but FET260 (IRFB42N20D) gets hot EXTREMELY fast. Within seconds you cant touch it. In the 81000D I just fixed that part did not get that hot that fast.
I'm not familiar with this section of the amp, if I had to guess it appears to be a voltage regulator. Any idea why it would be heating up so quickly?
No, they both read ~990 ohms and slowly rising while charging the caps.
I did notice though that one of the caps marked 220 10A has a VERY small dent in it. It's the one right next to the mounting screw. In this amp it says "e2 220 10V". I don't know if it would affect FET260 but I thought you should know.
