I´m very happy with my MiniMonitors (Jim Griffin´s superb blend of an E.J. Jordan JX92s fullranger and an Aurum Cantus G2Si ribbon tweeter, (http://www.esnips.com/doc/0cd36443-0972-477d-9e54-1267c790b359/JX92SG2siDesignPak), but they are somewhat inefficient. To make them a bit beefier, I`m thinking of adding an additional JX92s to drive them as MTMs.
My thoughts, so far:
The impedance minimum of a single JX92s is 5 Ohms, so 2 of these drivers in parallel have 2,5 Ohms. That might be a problem, but my differential Pass F4 monoblocks will handle that hands down.
The drivers´ absolute minimum distance, determined by the tweeter´s dimensions, is 9,5 centimeters. (measured from cone edge to cone edge)
9,5 centimeters is the wavelength of approximately 3600 Hz.
The crossover frequency will be approximately 3000 Hz with 4th order filter.
And now for my questions:
Will there be any comb filter effects?
Will a 3rd order filter give better results?
Will that work?
And, btw., what is the effective diameter of a cone driver? The cone alone or cone + surround?
Hope all that is not only bogus ...
Cheers!
JX92s: Jordan JX92S specifications
Aurum Cantus G2Si AURUM CANTUS Model G2Si DATA_SHEET
Will that work?
Cheers!
