mp3 data viewing software
The mp3 file is made up the following way according to this file:
<a title="Traced by User:Stannered, original by en:User:Kim Meyrick, CC BY 2.5 &lt;https://creativecommons.org/licenses/by/2.5&gt;, via Wikimedia Commons" href="https://commons.wikimedia.org/wiki/File:Mp3filestructure.svg"><img width="512" alt="Mp3filestructure" src="https://upload.wikimedia.org/wikipe...estructure.svg/512px-Mp3filestructure.svg.png"></a>
Opening an mp3 file in a text editor results in the following picture. Is there a way to view the mp3 file data values, I have used Audacity, but maybe as a set of values in a text file.
First I want to see the values of the sound values for each 1/144K second. I want a list of these so I can import it into a spreadsheet and do some charting and analysis. Then, ideally, I would like to write back the mp3 file after processing it, or use a tool to write it back.Audacity features difference tracing between files but I am not sure how to use it: for example how does a .wav file minus the .mp3 of the same file sound? What is the difference, value wise.
The above links really look very promising, especially with Python.
Progress:
Python Code:
Python:
import wave
obj = wave.open('Track1.wav','r')
print( "Number of channels",obj.getnchannels())
print ( "Sample width",obj.getsampwidth())
print ( "Frame rate.",obj.getframerate())
print ("Number of frames",obj.getnframes())
print ( "parameters:",obj.getparams())
obj.close()
https://www.tutorialspoint.com/read-and-write-wav-files-using-python-wave
Output:
Code:
Number of channels 2
Sample width 2
Frame rate. 44100
Number of frames 12028716
parameters: _wave_params(nchannels=2, sampwidth=2, framerate=44100, nframes=12028716, comptype='NONE', compname='not compressed')
I was able to use the above code to extract data from 10 frames. Using this data in a spreadsheet, (Open Office Calc) I was able to create the chart shown below. I am not sure if the data is from two channels, probably is. The data is for 10 frames, which is not a lot of time, at 14.1 k Hz, each second will need 14,000 cycles out of the 12 million or so total. Still it is a start.
This is the method I plan to use: extract the data from each channel into a numerical format, and use a spreadsheet to plot and analyse the data, for example, how a compressed file, converted to .wav, loses data compared to an uncompressed .wav of the same file. I have not come across anyone
doing this analysis yet
The code for generating the above data only (hard coded to 100 frames ) is listed below.
Python:
import wave , struct
obj.close()
wavefile = wave.open('Track1.wav','r')
length = wavefile.getnframes()
for i in range(0, 100):
    wavedata = wavefile.readframes(1)
    print(wavedata[0])
