Mounting PCBs in Rack Enclosure
How do you mount PCBs to the bottom (or top) of a rack enclosure without anything like a pan head sticking out?
In commercial gear there are usually depressions in the sheet metal to account for a screw head. Is there a hand tool that can do this sort of thing?
I've got a nice Hammond 1U RMC enclosure but there is absolutely no room for screw heads above or below. I am at a total loss as to how to actually mount anything to this enclosure.
You can use a flat head screw, and countersink the hole so it sits flush. The little plastic snap posts can have a very low profile as well. Pop rivets have a low profile, you could use them to mount some sort of internal brackets.
Yeah, I think the coutersink method is just about the best method at this point.
I can't believe there's not a better way to do this. After searching the WWW I am really NOT impressed with sticky tape'd plastic standoffs and other such hackery.
The standard male-female standoffs are not quite right:
Anyone know of a 6-32 0.25" / 6.35mm hex standoff with a shorter male end like only 3mm long?
I found male-female M3 5+4mm standoffs. And the 0.5mm pitch thread would mean up to 4 threads would grip 2mm sheet metal whereas with 6-32 only 2.5 threads would grip. With a washer these standoffs might not stick through more than 1mm or so. If the hole were just right, brass into aluminum might not even need tapping.
But I suppose the countersunk screw method is probably still a little better. But with these parts:
The two screw ends might butt into one another leaving about 0.087" slack by my calculations. Unfortunately I have found that 1U enclosures can be very tight with things like radial capacitors (especially filter capacitors of power supplies). Maybe a washer could take up the slack.
The square rod idea is interesting. If the intention is to lay down a long square rod extending beyond the ends of the PCB, that would also solve the butting threads problem with standoffs. The only problem is that I do not have the tools to accurately drill 0.25" square rod.
