I built Leak TL/50 Plus from scratch ,point to point. The only thing I changed
is the layout: Kt88, EF86, 12ax7 KT88 in that order. All voltages appears fine.
The amp is playing wonderful untill I connect the Feedback. Then it started motorboating at a rapid pace. OK I know for sure that is connected right. It's
Edor transformer and it was in another amp. I tried many resistor but it only
stop if I use like 1 or 2 megs.
OK, I am a dilettante and I am working with only a mulitimeter. Any help or
suggestions will be appreciated.http://44bx.com/leak/Leak/Circuits/tl50_ecc83.JPG
The secondary has an 8 ohm tap and is not symmetrical. It would be symmetrical if there were
only 4 and 16 ohm taps. Here it is not appropriate to switch the 0 and 16 ohm secondary connections.
As an alternative to rewiring the output transformer primary, instead you could exchange the driver
connections to the grids of the output tubes.
Wow! I am so happy. I don't know if you guys understand how valuable your help is;how
much it is appreciated. Rayma, your are the champ! I did exactly as you stated and there
is no more motorboating. How sweet it is not to hear it.Thank you, thank you and thank
you a million times.
