I don't want to be the bad guy here, but we've so far had a few people tell us about the obvious differences that they and some test group have noticed between amps, yet each one is just a "one day, we did xyz" story. No published results. Lets see some facts, and things will get fairer than word-of-mouth storytelling.
That being said, even though I sit more on the "amps aren't your biggest problem, ever" side of the fence, I will admit that amps DO impart a sonic signature of their very own. But, as I understand (and I could be wrong), many cheaper amps (say the $200-$1500 range) could be modified to produce a signature much more like a $20,000 amp, for only a few hundred dollars and a few hours of engineering. (In fact, Bob Carver has done EXACTLY this, I'll try and find the paper).
I am still entirely undecided on the matter, but I do know that there is NEVER a valid reason to spend $100k on an amplifier. Even if the "Every amp sounds very different" crowd is right, that does NOT mean that more expensive is always better. Accuton diamond tweeters, for instance, are stupidly expensive, and yet have nothing on the somewhat cheaper raven 3.2 MMX ribbons or the vastly cheaper scanspeak revelator tweeters.
And as long as we're all stuck in the stupidity of passive crossovers, I'd say amplifier signatures are the least of our worries. Give me a good active xo/dsp (the DEQX will do) and a whole bunch of crown amps, and you can keep your $20,000 amp and outdated, powersucking passives. 😛
Flame suit on (just having a bit of fun guys, I'm not trying to crush anyone's thoughts here. This thread should be kept light-hearted)
Nobody's forcing you to agree with him.
"...no one has ever (yes, ever!) heard a difference between two amplifiers..."
Peter Alcatraz
It is worse than that.
Oh good, the crazy thread has re-emerged.
Can I ask a purely semantic question of all you difference theorists? A kind of series question that is? A thought experiment?
For the purposes of the experiment it is necessary to introduce the concept of a 'perfect amplifier'. This is a kind of mathematical idea, such as 'zero' or 'infinity' or 'in the limit'. A perfect amplifier has an output identical to that of the input other than in scale, i.e. it is more powerful or, if the output is applied to a suitable 'perfect attenuator', it will exactly resemble the input. This is an amplifier of the mind.
Is it not the case that it is the intent of an amplifier designer to create an amplifier whose sound is indistinguishable from that of a perfect amplifier?
If 2 different amplifiers, regardless of construction, have a sound, each of which is identical to the sound of a perfect amplifier, will not then their sounds be identical?
This is the crux of what Peter Aczel is saying.
Evidently some people think that this is not the case, but I can assure you that within the commonly accepted meanings of the words I have used, it is the case.
w
Oh, misspelling his name. How low do you want to go? How bad do you want to look?
w
The question is an insult in itself! Did you say theorists?
Look dude, if you can't hear any difference it is alright but we are not theorists, we are talking about lots of years of endless practice.
Do not dare to talk about semantics... please....
What is happenning here???
I don't understand what's WRONG with the editor statement ("...no one has ever (yes, ever!) heard a difference between two amplifiers..."). 😕
And I don't understand either what's WRONG with HornTube statement ("Most idiotic statement in audio history") 😕
The editor was "right" when he implied that in a CONTROLLED situation it is PRACTICALLY impossible to hear subtle differences (and the referred blind test is not really controlled), tho the differences are RIGHT THERE. Imagine just how many people, ignorantly, comparing devices (e.g. doing a blind test) without a controlled environment.
Yes, there are people with better hearing. And I think I have one also, a sensitive ear, tongue, feeling, and I think I can sense a "ghost" around me either 😀 Well, my boy seems to be able to see them, make me scared! (of course I'm not scared of the "things" but I'm afraid of what may happen to my boy, or what he is going to be. I don't know whether I should try to stop that or just let it be).
HornTube and John Curl are of course right with their statements. But I believe that most of those in their "camp" are more idiotic than the editor.
If you seek for absolute correctness in any statement, of course the editor's statement is wrong, and so is HornTube's statement. Because it is certainly not the MOST idiotic statement in history. May be the 12th I'm not sure...
Can I ask a purely semantic question....
That's not a semantic question, it's a tautology.
The best is to taste the output leads with the tongue
Can be quiet useful (serious) for checking out the output if you don't have a voltmeter.
Look, for me it is the most idiotic statement. Period.
We are not in East Timor here...
Okay so we are in an uhm... millenium country. How do you define a controlled environment? (I believe that a perfectly controlled environment is just not achievable practically. The editor might only said a few examples). As you said, your listening skill is developed from years of practice. Were those years of practice with a controlled environment? Of course not.
Actually, one single GENERAL statement cannot make us seen like idiots. But too many may. And there are idiots in both camps so let's stop in case we are one of them 😀
I agree that it isn't the MOST idiotic statement in Audio history. One only has to search the name "tspence" on diymobileaudio.com forums to see that.
Mr. Curl, please try Baxandall´s difference test with equipment (above certain level conservative measured performance), hear output difference signal (with real level compared to input signal-music), and compare this heared "nothing" with differences, You "hear"..Ears are very unreliable and mostly show us differences between ears and expectations..Yet my ears show me differences.
I might say something, I hope conveys at least my experience. First, double blind testing will not show any subtle differences, but that could be said the same with a double blind test between New Coke and Old Coke, or even Coke, Pepsi and some generic cola. A VERY rigid test of this type will obscure these differences, even if they are obvious with extended listening, or tasting.
Still, I have never made a preamp or power amp, (and I have designed plenty) that really sounds exactly like another. AND the latest design is NOT ALWAYS the best sounding.
This is my experience, and it is refreshing that some here notice this.
Agree , All electronic devices sound different ......
Keep your opinions, HornTube, but you will find only criticism here. Those who criticize you do belong to a group that subscribes to a few books and their authors, leaving behind what most of us actually experience.
I have many hundred books on the subject of audio and physics, but these do not count, because somebody, somewhere, has stated that I am kidding myself with what I design and its effect on the general public.
a shame but true .....
Audiophilery looks like a religion. As in a true religion, "True believers" make pontifications on the One Path to Enlightenment (or Multipath, as the case may be here!). Followers strive for this condition; sinners follow poorly, and heretics oppose it openly. It seems to have the structure of a religion.
Now, a proper religion has no rational argument for or against it; "God" can neither be proven to exist or not exist (though proponents and opponents both insist the correctness of the fallacious proofs for their respective cases). This is one reason why the world's major religions have stood the test of time. They endure because they can't be disproven.
The thing is, audiophilery fails to pass this test. Using scientific methods, it has been proven that certain claims made by the True Believers are, in fact, false. A religion cannot be disproven, but audiophilery has. Then it cannot be a religion. Accordingly, all people interested in the subject must be alerted to this conclusion, lest the waste their lives on false pretenses.
True believers resist this conclusion, taking many familiar approaches in a vain attempt to deny the conclusion. We have already seen some in this thread: "who does xxx think he is!?" -- questioning a person's quality rather than his conclusions is an ad hominem attack, a fallacy.
Doesn't this bother anyone? How can we have a well-reasoned discussion about anything if reason goes out the window?
I have a question for the True Believers (you know who you are 🙂 ): do you believe you can produce a true, non-fallacious defense of your beliefs, in light of the OP's statement? If so, are you willing to have it debated in an honest fashion, with no fallacy, no trolling, only rational argument?
What is at stake:
If you accept that it has been disproven, then you accept that all of these things (CD players, amplifiers, cables, etc.) have no difference, and that any difference you think you have experienced was, in fact, a lie. This is a difficult admission for anyone, but a virtuous person will recognize the overwhelming force of reson and concede this point.
On the other hand, if you can prove that it is true (through a similarly scientific and rational basis), then all research (such as the OP's statement) will be cast into doubt! Remember, this is a Good Thing, as science is inherently self-doubting and will greatly value the proof of fallacious data. Indeed, your conclusion could lead to new experiments that prove the existence of this difference. Not only would your belief be verified, others will have no choice but to agree!
The only thing I ask is that all subsequent respondents follow a rational argument. I will gladly point out any fallacious statements, keeping things focused and on track. We can collect rational arguments, for and against, and in the end, decide which arguments are most valid. Finally, we can reach a conclusion, once and for all, deciding if it's really true or not!
Such a solution should please the moderators, no? Fallacy leads to attack which leads to bad threads. Perhaps the moderators may even help me with my proposed ground rules.
Tim
this thread is pure kryptonite ...some forum members will rip your liver
and give it to vultures, or at least will remove your scalp .
I personally appreciate the courage of people,
I like the boldness also ... and I think a good
controversy is also an interesting spice ... yet
use of names, the nominal charge, will complicate your
relationship with the moderators ... they hate direct charges
pointing fingers ... they want us to be saints.
Please, inform uncle Charlie the cigarrete brand you smoke,
also the drink you like...i may visit you (maybe) in the sin bin
providing you some confort, celebrating your suicide courage.
regards,
Carlos
LOL.. so true Carlos ..... 😀
Wow, this is a wildly controversial thread...
To sate my own interest, I built that Amp testing remote controlled gizmo from ESP that lets you switch amps on the fly with same preamp and speakers to identify differences between just the amps.... I tested my Krell KSA-50 Clone and the Aleph 5 I built. The difference was tiny (gain adjusted) and was quite surprised...I like the Krell just a tad more...but not anywhere near as much a margin that I previously had before building the gizmo...I remember thinking the Krell totally trounced the Aleph...not so.. I have heard a much bigger difference changing out the opamp in my DAC than swapping amplifiers.
Also keep in mind these are two extraordinary amps...
One has to wonder why this is such a hot topic....why do people get so bent outta shape over this?
Preamp - Aikido 6SN7/6SN7
Speakers - Magnepan Tympani IVa
DAC - Home made Cirrus 4398 jobbie
very interesting results John ....
The paradox is that if people accept the notion that you can't
hear the difference, then the entertainment is over, and both
the critics and designers can go home.
LOL.. .So true ....... 🙂
- Member Areas
- The Lounge
- Most idiotic statement in Audio history...
