Mosfet Spring Retainer Clip Replacement?
Does Anyone have a source for these clips? Sometimes amplifiers are missing them or they break when removing them. Whatever the case may be. Alot of amplifiers use them. I have been searching high and low, amplifier manufacturers in china asking them to sell me 1000-10000 pieces. i just can not find the correct source for them. Does anyone know of a replacement?
:yikes:😱:headbash:
They look the same but the bend varies. Some of the clips won't lock securely into other slots.
I was using these but they're getting harder to find. They work for TO-220 and for larger transistors if you double them. They're not reusable. Use octopart to find them if you can't find anything better.
AAVID Thermalloy 4525
Many times, I had amplifiers that were not able to be repaired or not worth repairing. In some cases, the owner will give you the amp. If they won't give them to you, $20 will often be enough to buy them. That's one way to get parts like the clips or terminal blocks that you cannot get in any other way.
That generally where I get them. When I was just practicing on amplifiers I destroyed more and had clips. Now the better I become at repairing amplifiers the less damaged or non repairable amplifiers I have.
REPLACEMENT FOR THE SCREW TYPE
I used a stainless band clamp of steel 1-1/8th lond by .5" tall. 2mm in thickness. It doesn't bend under the force of the new stainless m4x8mm hex cap screw.
The parts needed.
A m4x8mm hex cap DIN912 (Alibabia) there are plenty of places to buy them.
US $3.28 25%OFF | DIN912 M3 M4 M5 M6 M8 Metric Thread 304 Stainless Steel Hexagon Socket Head Cap Screws Inner Hex Socket Bicycle Bolt 4mm-50mm
DIN912 M3 M4 M5 M6 M8 Metric Thread 304 Stainless Steel Hexagon Socket Head Cap Screws Inner Hex Socket Bicycle Bolt 4mm 50mm|din912 m3|socket head cap screwcap screw - AliExpress
The band clamps are used on 1" stainless steel bands. EBAY
Signode USA 1/2” x 1-1/8” Metal Banding Clips Seals NEW USA ( 100 Pcs. ) | eBay
