Hi all!!
I am trying to build a MOSFET power follower run from +12v and -12v batteries. The -12v is connected to a 3A Constant Current MOSFET. The upper MOSFET is biased for 3A. Both are the same type of N-channel MOSFETS.
So I am looking for MOSFETS that are temperature stable, relative high S, low Ciss, and linear to 8v. They also have to handle 35W of dissapation each.
So any ideas for make / model of MOSFETS? Also looking for an easy CCS using a N-channel MOSFET. (thinking something like the Nelson Pass CCS on the Zen Amp.
I will probably let the batteries drain to about 10v before recharge.
Low drifting is a must. The output is DC coupled to the speaker.
I simulated the circuit and it seems to work ok. THD is very low until clipping.
Any recommendations or ideas are welcome!!!
tia,
Richard
tia,
Richard
