Hello, what do you think of the next amplifer?
Is the amp will work good with headphones resistance between 32-600 ohm?
Class-A amp. It will consume 60mA all the time.Hello, what do you think of the next amplifer?
Distortion not too bad (in simulation : 0.1%)
The input signal is amplified 7 times
Normaly yes, it will. (it depends of the headphone)Is the amp will work good with headphones resistance between 32-600 ohm?
50mW max for 32ohm headphone
87mW max for 70omh headphone
10mW max for 600hom headphone
But of course, all these numbers won't tell you il what you'll hear will be great or not
