I have a power amp circuit with mosfet output transistors. The amp was damaged by dropping it. The amp blows fuses and the power transformer is fine. Do I check these transistors or do they normally fail open circuit?
My experience with Mos-Fets is they are difficult to test with just a meter. Its better to put them in a simple test circuit and vary the gate voltage to see if they behave as they should.
Different types of Mos-Fets require different biasing but basically changing the bias voltage should change the current through the device.
There should be virtually ZERO gate current.
If an amplifier has been dropped, the first call would be to carefully check all connections for broken solder joints.
Failure mode is almost always a near or total short for common vertical power fets.
Use a bulb tester and fault find in the normal way.
If you can achieve zero D-S current with G bias then they might be OK
If you can identify the MOS-FETs then we can be more specific as to how to test them.
Thanks. Will check the fets.
The FETs dont fail from a drop. More likely u have a short somewhere in the voltage supply circuit.
You probably have a cracked circuit board or trace. Mosfets usually fail shorted from over voltage, over heating ( excess current ) or excessive gate voltage. I have rarely seen them measure open unless their plastic covering had exploded due to the initial short.
- MOSFET failure usually open or closed
