Mosfet Citation 12 - Negative swing clip first
When input is shorted locally the noise is the same Nelson (same buzz sound, same level).[/QUOTE]
This happen to me when i finally set my amp on the casing. before i arranged the wiring to make it looks good, but problem on hum and oscillation occurs so I have rewired the system the shortest wire possible and put a 68ohm resistors soldered directly on the bases of the output Mosfet.
Then I think that either your grounding arrangement is
defective or the power supply rejection is not good.
For the latter, try using a larger capacitor on the RC
filter than supplies bias to the differential input pair of
transistors and see if that makes a difference.
