https://www.hificollective.co.uk/sites/default/files/mdt-33-datasheet.pdf
Morel MDT33 -legend MADE IN ENGLAND
condition close to new
i have 2 pair this one used once for test
sound very close to beryllium tweeter sound
clear and crisp
box and all pack original condition
400$US pair
These tweeters represent the finest in soft dome tweeter construction. Features a treated 1-1/8" soft dome, ferro fluid cooled aluminum voice coil, and double magnet system that is vented into a damped rear chamber for exceptional power handling and exceedingly low distortion.
Specification:
Znom 8 ohm
Re 5.2 ohm
Le@1kHz 0.09 mH
VC height: 2,7mm
Air gap height height: 2,5mm
Lineal coil travel: 0.2mm
fs 700 Hz
Mms 0.44 g
Sd 6.0 cm2
BL 6.3 N/A
VC Ø 28 mm
Sensitivity 1W / 1m 92.5 dB
Nom. power DIN 200 W
Weight 1.1 kg
clear and crisp
400$US pair
Specification:
Znom 8 ohm
Re 5.2 ohm
Le@1kHz 0.09 mH
VC height: 2,7mm
fs 700 Hz
Mms 0.44 g
Sd 6.0 cm2
BL 6.3 N/A
VC Ø 28 mm
Weight 1.1 kg
