more gain please
i'm amplifying a Denon DL-160 Phono Cartridge
here is the spec:
Output: 1.6mV
Stylus: .1 x .2mm special elliptical diamond
Cantilever: aluminum
Frequency range: 20-50,000Hz
Compliance: 14x10-6cm/dyne
Tracking force: 1.3-1.9g
Weight: 4.8g
with a Burr Brown INA103 and im getting a gain of about 55dB and i need 75dB
so my question is how do i achieve a range of 70 to 80dB with a buffer, what kind etc...
here is the schematic:
and my hack:
by the way it sound wonderful with a 64-Bit RIAA Vinyl Correction Curve. (pure vinyl)
thanks
Martin Gagnon
Look at U1B in the second picture of this thread:http://www.diyaudio.com/forums/analog-line-level/177393-diy-dj-mixer.html It is set up as a unity gain buffer with input resistor of 10k and feedback resistor of 10k. You want about a gain of 4, so the feedback resistor should be about 39k or 47k. The feedback resistor is the one coming from the point of the triangle (the output) to the minus input. Metal film resistors make the least noise. Put the gain 4 buffer between the point of your device and the output. Your power supply looks okay for 5 more milliamps. The drawing shows 5532 op amp. I like ST33078 or NJM4560 for better slew rate & noise specs. Both of the latter numbers you have to put .01 to .1 uf disc caps on the power supply within an inch of the IC, and a 20 pf or so disc cap across the feedback resistor, to prevent oscillation. Some people say 4562 is even better than 4560, but I haven't tried it or the 5532 either. Watch on 5532, the most common package I have found is 14 pin DIP which is different pinout than the 8 pin dip package of 33078, 4560, 4562. You have to check the datasheet (from datasheetcatalog.com) of what you buy against the pinout shown on the +in, -in, and out, of the schematic on the link. Watch buying SIP package: they are made, but hard to buy IC sockets for. For a board to put it on, look at Small IC Prototype Board | 21-110 (21110) | Distributed By MCM
Don't forget to buy 10 uf electrolytic caps to put on the op amp PCB, sockets, standoffs and screws to screw it to something, and hookup wire. Get it all on one $6 shipping fee. Farnell.com operates in Canada, also somebody recommended future in Vancouver. Crossing the border runs freight up to $12 or more UPS; maybe cheaper USPS/RMail.
Close. The 20 pf cap goes in parallel with (across) the 47K resistor not in series with it. It shorts out the 47k at very high frequencies, causing the op amp to have low gain at those frequencies (which you can't hear anyway). The 10 uf just need to be on the PCB somewhere near the second op amp. The fast op amps also need a .01 or .1 disc cap really close, I put mine right between pins 8 & 4 of the socket on the back. You may be able to get away without the disc caps on a 5534, I've never used it but it's slew rate is slower. You also need a 10 k between the output of your old IC and the minus in of the new one, and a 1k from the output of the old amp to signal ground.
I don't have a datasheet on a 5534, I think the pin numbers you are using are for an obsolete TO5 round package or something. On the 8 pin dip package that nearly everybody stocks, 8 is plus supply, 4 is -supply, 5 is amp plus in, 6 is amp minus in, 7 is amp out, other amp (2 to a package) 3 is plus in, 2 is minus in, 1 is output. when you get them, pin 1 has a dot on it, or if there is only a cutout on one end, holding that end up pin 1 is top left from the top side. Legs point down at the socket. Count pins counterclockwise from the topside. To be really specific I have ST33078N's from farnell.com (newark.com in NC, USA) with legs that plug into tyco phosphor bronze sockets I soldered into my disco mixer. The D package has the legs cut off and bent for surface mount package, which package you only use with $50000 wave solder machines (you don't have). Put the op amp in the socket after the soldering is all over, and inspect for bridging, it is hard not to bridge those tiny pins. (I did it twice in 4 op amps, had to suck the solder off with old stripped wire).
the inverting opamp has a gain set by the 47k and the total source impedance seen at the -IN terminal.
If INA103 has Zout = zero ohms then the gain is -4.7 (+13.44dB inverted).
The opamp also multiplies the INA103 noise by the same factor, +13.44dB.
You asked for 10times (=+20dB). you need a ratio of 1:10 for those gain setting resistors.
I cannot see the extra 1k loading the output of the INA103 as having any advantage. My view is that it reduces the performance of the INA for no benefits at all.
I noticed that the input gain setting configuration is not per the recommended configuration in the TI/BB application notes. Should be 15 & 13 tied together, and 6 & 2 tied together with the gain setting resistor (or rheostat connected pot) placed between them. The gain equation as implemented currently will be incorrect. This is actually a pretty serious error and also has implications for CMRR performance if you are running a balanced connection. (Not to mention DC offset) To fix just jumper pins 2 & 6..
Note also from a noise perspective it would be better to realize as much of the gain as possible in the front end of the INA103 as opposed to an external op-amp as that device will also amplify all of the noise generated by the INA. 60dB is possible with an INA103 with an rg of about 6 ohms.
The differential input impedance needs to be 47K to properly load the cartridge, I'd change those 10K input resistors to 24K which would be close enough. I doubt this is having a huge effect on cartridge performance since the generator impedance is pretty low.
I'm also puzzled by why you think you need so much more gain with a DL-160, with "just" 60dB of gain you'll get 1.6Vrms @5cm/sec which should be more than enough for most applications, and if it isn't you'd need only a couple of dB more. Your proposed gain would result in 4.8Vrms (70dB) and 16Vrms (80dB) which is clearly a bit over the top.. 😀
Note also that the inverting mode of operation in an op-amp has an inherent noise disadvantage because the (noise) gain at the non inverting input is 1+Rf/Rin and at the inverting input Rf/Rin. This is very significant at low gains. (Worst case is a unity gain inverter where the noise penalty is 6dB) Note that most modern op-amps have sufficiently good common mode performance that inverting operation is not going to cause meaningful errors in audio applications.
Personally I think you'd be better off applying the EQ in the analog domain and then all of the frequency dependent headroom vs SNR issues go away at the input of your ADC...
putting the inverting opamp second in the amplifying chain avoids this added noise problem, particularly when the previous stage has lots of gain and the inverting stage uses a low noise configuration (combination of opamp choice and resistor values).
True, it is not a big contribution given the huge amount of gain ahead of it, but I was trying however to suggest that perhaps that op-amp is not needed at all. (And raise the OP's awareness of noise issues in general) It seems to me that the OP really doesn't want the kind of output voltages implied by 70 - 80dB of gain. At 80dB an op-amp providing the additional gain would have to be running on +/-25V rails minimum and there are few that can actually do that. (OPA445 is one that can)
I use less gain with a 350uV LOMC (65dB with passive EQ) and get sufficient output level even for the ADCs in my media server.
the first ina103 preamp i build had 2 times 23.7 kohm and sounded more harsh compare to 2 times 10 kohm.
i had no input cap either, so im not sure what does what but i can tell you dusty springfield (the look of love) is simply perfect.
right now im recording with an Audio-Technica 440MLa and i get the same top end richness. in the past i use to hate this cartridge for the bright top end on my old phono pre.
Martin
The AD797 looks good, but with 8 MHz gain bandwidth product you better put .1 disc caps very close on power supply. You would need two since it is a mono part. It has a static warning, must include fets. LM4562 has 45 mhz gain bandwidth, 20V/us slew rate and is $3 at digitech this week for 2 in a dip package. ST33078 sounds really good, 10 mhz gainbandwidth, 5 v/usec slew rate, 15 ma drive, lot less power supply current than Ad797 and is $.60 for stereo DIP package and has no FET's and took a lot of mistakes without blowing up on my disco mixer. I had hoped your conversion of circuit to application note per Kevin's note would get enough gain. Have you thought of increasing the feedback resistor on your power amp op amp to get more gain there? most pro power amps have an op amp on the input. My Peavey power amp uses NJM4560 op amps, another good part. Also available as RC4560 from TI. Any of these parts watch package code, they come in SOT which is useless for amateurs and SIP which doesn't fit most sockets. My ST120 power amp has way more gain than the Peavey, something about a hfe 150 input transistor to make it compatible with the low gain tube PAS2/3 preamp, hugely popular in 1966 and not like modern equipment at all.
Martin, how is it going with this preamp. I`m in a similar situation and luckily found this thread. So I want to archive my vinyl. I would like to use my soundcard since I have the option to apply real time RIAA with the onboard DSP. I´m in process of re-wiring my tonearm to balanced configuration and I would really like to stay that way all the way to my computer. I`m using MM cartridges and what I have read, the problem is loading these high gain mic-preamps...I´m relatively new to electronics so be gentle 🙂 Any ideas?
Jarno
