More Delay?
Is there any way to get more delay? Your 4 way Advanced Xover looks to be the closest to what I need except that I need more delay to sync my subs. I'm trying to make a small portable system without having to carry piles of rack gear around
Unfortunately no. This platform won't allow it, else we would have definitely put it there. If this is a portable system, then moving the sub in to make sure the delay requirements are minimum might be the easiest way to make it work.
Is it that the system has used all the available processing? if so what do custom plug-ins cost?
Yes, that's correct. This unit is already providing a lot of processing for the size of the board.
As for custom plug-ins, they only apply to OEM deals, so I'm afraid that it won't work.
May i suggest you think about why you need more than 2.53m of delay? With the suggestion I gave earlier, reducing delay by moving the sub in space rather than moving it in Digital domain, I've experienced many times in my P.A days that sometimes it's only a matter of doing proper physical alignment of speaker boxes, vs trying to get the processor to do the work. E.g. place the sub below your horn/mids box and you'll see when you time align with an Impulse response that 2.5m is quite a lot..
Anyway, my 2cts
I wish moving the sub was an option but the IR of some of my tapped horns is as much as 26ms, so it be a little ridiculous have it that far forward and not possible in areas. Guess I'll keep hauling my MediaMatrix around for now
Thanks, maybe it will be possible for miniDSP in the future
