So, what did it cost?
I spent about:
Amp boards: $140
PSUs: $150
Protection: $50
Heatsinks: $50 (2nd hand salvage)
Meters: $40
Power transformers: Free (salvaged)
Epoxy: $150
Signal Wiring: Free (salvaged)
Wire Dressing: $10
Power switch: Free (salvaged)
IEC/Fuse/EMI filters: $10
Mains Wiring: Free (salvaged)
Steel: $100
Rivet Nuts: $10
Fasteners: $50
Primer: $20
Paint: $60
Mahogany: $5
Danish Oil: $10
Clear Coat: $10
Total: $880
This is all in New Zealand dollars of course.
Probably somethings like $450 in USD/Euro.
Pretty darn good considering what monoblocks go for in the commerical space.
Without the meters and epoxy I would have saved a lot but they wouldn't be quite as cool either.
These are all estimates/guesstimates. I can't be bothered working things out exactly but its probably an over estimate.
Of course the extreme cost savings come at the cost of a lot of time. But time is something I have and spare money is something I don't.
Being in the early stages of family and mortgage, a shoestring budget is the only way I can afford to build.
I was lucky with some things:
The mosfets which I got for $3 each (NZD) on clearance from our local brick and mortar store Jaycar electronics.
The heatsinks were 1 giant heatsink I cut down that just happened to come up cheap on Facebook marketplace. Otherwise heatsinks are expensive in New Zealand as nobody sells anything of any decent size locally.
I get access to lots of heavy duty wiring and switches for power supplies from old coffee machines through my work.
Small signal wiring I have a liking for cutting up old network cables.
Internal speaker wiring I simply cut down my actual speaker cables a bit since they are far longer than they need to be. Some good quality audioquest stuff I got many years back.
Power transformers, I just happened to have a pair of matching transformers salvaged from different model pioneer home theatre amps I collect second hand whenever I see them for next to nothing.
The mahogany was from a nice chunk I got for $20 second hand from some kind of wood salvage guy.
Most of the time was spent on metal working but I ended up with exactly what I want. A pair of modushop mono block chassis would cost me more than the whole build albeit with much nicer machining than I am capable of right now.
With all this practice, my metal working skills keep getting better. I am making less mistakes and this being my 2nd iteration of this modular chassis design, I made less design errors this time round. That's not to say I didn't give myself some issues to work around.....
All this design experience and metal work practice will come in really handy when I get around to my next batch of monos: Most likely single ended Class A however I do have a set of wolverine boards to build one day.
I spent about:
Amp boards: $140
PSUs: $150
Protection: $50
Meters: $40
Epoxy: $150
Wire Dressing: $10
Steel: $100
Rivet Nuts: $10
Fasteners: $50
Primer: $20
Paint: $60
Mahogany: $5
Danish Oil: $10
Clear Coat: $10
Total: $880
Well done!
"heatsinks are expensive in New Zealand" yes...salvage salvage salvage. Great to see you have access to reusing parts. Especially like the 'coffee machine' bits and bobs!
- Mooly's MMAMFM Monoblocks - A build log
