I need help in finding a Moog amplifier schematic for a module I have had laying around for over 25 yrs. It has the numbers 980-0408118 on the bottom of the circuit board and the number
968-040706-001 on the heatsink. It runs on plus and minus 65 volts and has a array of 8) T0-3 outputs and 2) T0-3 case driver transistors. It is about 12" long and 4 1/4 tall.
Any help would be appreciated.
Hi Joe,
That shouldn't be that hard to trace. Old Moog diagrams would be hard to trace unless someone can share.
-Chris
-Chris
You won't find it under Moog. Do a search for "Lab Series" guitar amps. Various models like L2, L3, L5, L11, etc. Mostly the power amps are the same between them. If you need a specific model, try L5. The power amp you have is from one of them.
